Bluetooth devices not working
ErionA
I have a asus vivobook s14/16 S3607CA, when i try to connect a pair of earphones its not working as it should. When i connect earphones to my laptop they do connect but they are not working, the sound is coming from my laptop speakers not the earphones and i have tried more than one pair. Some of the things i have tried for fixing this problem are: updating the drivers, disconnecting the device and reconnecting, setting the earphones as the primary sound device downloading other Bluetooth driver from the asus support site for this device(but it still stayed the same driver (the realtech one) eaven tho i downloaded another one). Idk what else to try and where is the problem.
ErionA
Update!
I somehow fixef the problem although I am not really sure how. To anyone wondering what I did, I downloaded new Bluetooth drivers that are supported on this laptop and refreshed the sound settings for the browser i am using(In Windows settings, while your headset is not connected and Opera is closed, goto System -> Sound -> Volume Mixer and dlick the "reset" button to reset the sound settings for all apps. Then, connect your headset and do that again. And, make sure the default output device is set your headset Confirm again by hitting Windows key + r, typing msys.cpl and pressing enter. Right-click on the headset device there and set it as the default device if it isn't).
