ZenWiFi XT8 Backhaul connectivity problems after upgrade
rahulc73
Hi All,
I recently upgraded to Firmware Version :3.0.0.4.388_21617 and two nodes connect the main router only over 2.4GHz. When I was on Firmware Version: 3.0.0.4.386_48973, both the nodes would consistently be connected over 5GHz-2 backhaul without any issues.
Is there a way to fix this?
One way I found was to downgrade back to Firmware Version: 3.0.0.4.386_48973.
ASUS Support for the US is a drag. Not helpful other than sending lengthy emails with irrelevant fixes and asking to fill a stupid word document over and over.
12 REPLIES 12
rahulc73
Ten minutes into this research and changing settings, here are the changes I made to bring both nodes talking to the main router over 5Ghz-2 Band. Important: This time I did not downgrade to Firmware Version: 3.0.0.4.386_48973.
Basically I changed "Channel Bandwidth" from "Auto" Or other entries to "20Mhz" while enabling "160Mhz". Set the Control channel to 100 and hit save.
Check out the second picture. This has been stable since the past 15 min.
drsky
rahulc73
Hi All,
Same issue here. I had zero issue until the last firmware update (3.0.0.4.388_21617). Since this update, my node keeps on reporting a weak signal or disconnecting. Moving the node closer to the router did not solve the issue. I was about to downgrade back to the previous firmware when I found this suggested fix. Currently trying it.
grayson_ang
I'm having the same issue. Node is "weak" and 2.4GHz backhaul. Rahulc73's fix did not work for me, although I'm not using Tri-band smart connect. I like to separate my 2.4GHz and 5GHz networks.
grayson_ang
I factory reset everything and was able to get it to connect to 5GHz backhaul
