Asus F15 Low FPS/FPS Drops
Luis_Orlino
System: Asus F15
Battery or AC: on DC/Battery
Model: F15
My Asus F15 (rtx 3050) has low fps on games, like League of Legends. That game has a small requirements compared to RTX3050. It also has a FPS Drops. I dont know whats causing this. Im using the RTX 3050 not the CPU Integrated Graphics. the temperature is normal, even the CPU Temp is normal.
11 REPLIES 11
john123marshal
4
Are you using BatteryBoost?
NVIDIA BatteryBoost extends battery life by limiting the maximum frame rate. This reduces the load on the GPU and therefore power consumption. You should be able to adjust or disable this feature in GeForce Experience.
Luis Orlino
hi I just reset the system. Still monitoring on it
great, then it will be settle down.
ASUS_Bot
Rising Star II
