Asus F15 Low FPS/FPS Drops
Luis_Orlino
System: Asus F15
Battery or AC: on DC/Battery
Model: F15
My Asus F15 (rtx 3050) has low fps on games, like League of Legends. That game has a small requirements compared to RTX3050. It also has a FPS Drops. I dont know whats causing this. Im using the RTX 3050 not the CPU Integrated Graphics. the temperature is normal, even the CPU Temp is normal.
11 REPLIES 11
Luis_Orlino
I also check the Power Plan and my Armoury Crate is on Performance.
Luis_Orlino
Its like on Power Saving Mode. Even upon booting at the desktop menu its a bit laggy
Falcon_ASUS
Luis Orlino
@Luis Orlino
If you are sure that the laptop is not overheating, but there is a system laggy problem. I would recommend you to backup your data and restore the system. If the problem persists, it may need to be checked for repair.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
4
Are you using BatteryBoost?
NVIDIA BatteryBoost extends battery life by limiting the maximum frame rate. This reduces the load on the GPU and therefore power consumption. You should be able to adjust or disable this feature in GeForce Experience.
