Asus F15 Low FPS/FPS Drops
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-23-2022 06:33 PM
Battery or AC: on DC/Battery
Model: F15
My Asus F15 (rtx 3050) has low fps on games, like League of Legends. That game has a small requirements compared to RTX3050. It also has a FPS Drops. I dont know whats causing this. Im using the RTX 3050 not the CPU Integrated Graphics. the temperature is normal, even the CPU Temp is normal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-29-2022 02:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-29-2022 02:50 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-29-2022 07:12 AM
Falcon_ASUSand what do you mean by back up and restore? do you mean back up and reset the system?https://zentalk.asus.com/en/discussion/comment/229525#Comment_229525
If you are sure that the laptop is not overheating, but there is a system laggy problem. I would recommend you to backup your data and restore the system. If the problem persists, it may need to be checked for repair.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-29-2022 08:06 PM
Luis Orlino@Luis Orlinohttps://zentalk.asus.com/en/discussion/comment/230090#Comment_230090
Yes, you can refer to the following.
[Windows 11/10] How to reset the PC and remove all of my personal files, apps and settings | Officia...Sorry for any inconvenience it may be caused.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-30-2022 01:38 AM
