RT-BE92u issues
rickysuper
I bought the RT-BE92u next week and had following issues after setting up the router.
Firmware version 3.0.0.6_102_37025-g530f5da_954-gd3ae6
1. VPN Server IPSec Client connect may cause the router reboot itself, even sometimes can connect but cannot browser the internet.
2. If any clients joined the 6hz channel. It will not possible to turn off Smart Connect to manually adjust the Wifi channels settings. Click Smart Connect OFF button and then Apply but no response, cannot switch to the Channels setting page until all clients disconnect from the 6hz channel.
2. One of the CPU coil always stay at 100% usage. It may happen on any of 4 coils randomly. Reboot the router may fix but not absolutely work.
4. Adjust settings may hang the router, need manually power off and on.
Any members had these issues ? I had reported to Asus support but no positive reply, just telling me they had no such issues.
Thanks in advance.
31 REPLIES 31
drbacterio
Stable but with some problem... I have detected that if the router firewall is enabled without configuring any rule, it is impossible to login on sites like aliexpress or with games like Startcraft II. Disabling the firewall it is possible to login without any problem. In other ASUS routers I had I never had this problem.
Lid
Well at least I am not alone buying buggy 300 quid paper weight. I've had the random disconnects and reboots to the point it's unusable, the thermal errors.  The power supply lead seems loose and you only have breathe near the router and it can fall out, causing another restart.  I've had to reset and restore my config twice now. It's currently working but I cannot use my external drive as it simply won't play ball. I notice in Windows Explorer the router has stopped appeared as a computer, likewise the media server is gone.  Leaving the AC68U to this cost me one USB port, I was prepared to live with only one external disc but now it seems any attempt to use this function causes the thermal errors to reappear.  What's galling is these features worked ok before the 37435 upgrade.
jimmysofat6864
I had similar issues here
https://zentalk.asus.com/t5/networking/asus-rt-be92u-random-loss-of-internet-connectivity-then-comes...
For me, my fix was install latest update, then factory reset, then keep a majority of the asus services disabled and so far it seems stable for now.
DesiBuckeye
Deleted - reposted
DesiBuckeye
I'm having the same issues.  Had completely unstable network after setting up router (with accompanying firmware upgrade). Came to this and other posts. Did the hard reset and set it up again, and the network is "less unstable", but still with issues.  I still have the log full of these issues below (more than thermal now) and also a "wave pattern" of speed/bandwidth, Core 3 bouncing close to 100% and RAM at about 75%
Errors:
Jan 23 13:44:18 bsd: bsd: Skip STA:7c:21:4a:58:91:ca reject BSSID
Jan 23 13:44:20 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 23 13:44:20 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 23 13:44:20 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 23 13:44:20 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On the graph, the blue line is download speed, orange line is upload speed. They're on different axes (as noted on the left)
