RT-BE92u issues
rickysuper
I bought the RT-BE92u next week and had following issues after setting up the router.
Firmware version 3.0.0.6_102_37025-g530f5da_954-gd3ae6
1. VPN Server IPSec Client connect may cause the router reboot itself, even sometimes can connect but cannot browser the internet.
2. If any clients joined the 6hz channel. It will not possible to turn off Smart Connect to manually adjust the Wifi channels settings. Click Smart Connect OFF button and then Apply but no response, cannot switch to the Channels setting page until all clients disconnect from the 6hz channel.
2. One of the CPU coil always stay at 100% usage. It may happen on any of 4 coils randomly. Reboot the router may fix but not absolutely work.
4. Adjust settings may hang the router, need manually power off and on.
Any members had these issues ? I had reported to Asus support but no positive reply, just telling me they had no such issues.
Thanks in advance.
31 REPLIES 31
rickysuper
It suddenly dead yesterday when adjusting the settings through web browser. It freeze and only Power LED light up after hard reboot. Normal factory reset and firmware restore both not work. Finally bought back to life by Hard factory reset (WPS reset).
Has it been working for last 5days?  I'm having similar issues with what I thought was Xfinity.  At first shutdown and restart would last a day and after a week of this it's now lasting an hour at most.  Let me know if you have any ideas
I did the Hard factory reset (WPS reset) after it dead (only power LED light up) and restore the backup configuration to the router. Disable the MLO channel and it runs better and more stable. No cpu coils suck at 100% but VPN IPSec server still not work. I enabled Open VPN and works but every reboot I need to manually switch off and then on in order to make the  initialisation complete.
rickysuper
I think this model or the firmware is still like beta and not stable. Need to wait for more official update afterwards.
