12-29-2024 11:09 AM
I got the RT-BE92U for my parents now but occasionally I get a random loss of connectivity across all of my devices then it comes back after a few minutes. Not sure if it’s because I enabled ipv6 or the qos settings or the TrendMicro security service or MLO which is odd because the previous SBG7600ac2 didn’t have this issue or even my RT-ax58U at home didn't have these issues and lots of these features are turned off out of the box. Trying to pin down if it’s the new modem causing the issue or the new router. Modem is ES2251 from spectrum if it helps. I tried checking the modem diagnostics page but spectrum locks it out and makes it inaccessible.
I had a similar situation a few days ago where phones and tablets weren't working but my laptop was for some reason and the inbuilt speed test on the router was working fine but phones were not working and eventually connectivity came back. Not sure if it's a bug or something I set up wrong.
12-30-2024 01:31 AM - edited 12-30-2024 01:31 AM
I encountered this many months ago on my AX86U when I updated my routers firmware. Couldn't determine whats wrong either as the thing that I just did is upgrade the firmware, nothing else. So I just downgraded to the last know stable firmware that I had before. ATM, I updated to the latest again, thankfully, that firmware no longer has this issue. I suggest downgrade to your know stable firmware or try check the latest firmware. Asus routers settings/configs could be backup anyway, so porting the new configs to the new firmware on a clean install of firmware should be good.
12-30-2024 06:41 AM
A new firmware has just been released a few days ago that solves many problems that several RT-BE92U owners have had. The firmware is 3.0.0.6.102_37435 and I recommend you to update it as soon as possible.
12-30-2024 10:41 AM - edited 12-30-2024 10:42 AM
I already am running the latest firmware version 3.0.0.6.102_37435-gdd27f25_1059-g807f7_BB0B and I still have the same issue.
I had Ai protection, QoS, apps analysis, Traffic Analyzer, MLO, and IPV6 enabled and I have high memory usage so I'm going to turn them all off and see if the situation improves.
01-01-2025 07:20 PM
Hi @jimmysofat6864 ,
Thank you for reporting the router issue.
To help us better assist you with the problem, we recommend that you check the following points one by one:
[Wireless Router] How to improve Wi-Fi Connection | Official Support | ASUS Global
