RT-AX53U does not have ability to block content
hmartens
I recently bought the Asus RT-AX53U specifically for the parental controls so that I can block content. After buying the router, there is nowhere to configure it. The documentation says to go to Family, but that only allows me to set times in which you can use the internet, no content restriction controls.
My router has the latest firmware version, 3.0.0.4.386 .
It's the only reason I bought this router for, now it seems that what the website/product says it can do, it can't! Please help.
Aureliannn_ASUS
Hi @hmartens ,
Thank you for your question about the Parental Control feature on the RT-AX53U.
Yes, the RT-AX53U router does support Parental Control. You can configure it through the web management interface.
To help us better assist you in resolving the issue, please provide the following information:
  1. Error message: What error message did you encounter when setting up Parental Control?
  2. Setup steps: At which step in the official FAQ did you encounter difficulties? Please describe in detail.
  3. Screenshot: If possible, please provide a screenshot of the problem you encountered. This will help us locate the problem more quickly.
[Wireless Router] How to set up Parental Controls?(WebGUI) | Official Support | ASUS Global
[Wireless Router] How to set up Family(Parental Controls) via ASUS Router App? | Official Support | ...
