11-15-2024 01:04 AM
I bought the RT-BE92u next week and had following issues after setting up the router.
Firmware version 3.0.0.6_102_37025-g530f5da_954-gd3ae6
1. VPN Server IPSec Client connect may cause the router reboot itself, even sometimes can connect but cannot browser the internet.
2. If any clients joined the 6hz channel. It will not possible to turn off Smart Connect to manually adjust the Wifi channels settings. Click Smart Connect OFF button and then Apply but no response, cannot switch to the Channels setting page until all clients disconnect from the 6hz channel.
2. One of the CPU coil always stay at 100% usage. It may happen on any of 4 coils randomly. Reboot the router may fix but not absolutely work.
4. Adjust settings may hang the router, need manually power off and on.
Any members had these issues ? I had reported to Asus support but no positive reply, just telling me they had no such issues.
Thanks in advance.
yesterday - last edited yesterday
After updating to the new firmware on the 24th Dec, I’m getting those log entries too. CPU Core 2 is running much more intensively than the others. It’s not normal. They have gone away after a reboot. Will need to keep an eye on it.
It has been otherwise stable since the new firmware and hard reset. Also, no more slow-to-wake connections on idle devices.
yesterday
new version! ASUS RT-BE92U Firmware version 3.0.0.6.102_37435.
I'm going to try it and see if it fixes anything.
yesterday
I've been doing really well since I updated to 37435.
