11-15-2024 01:04 AM
I bought the RT-BE92u next week and had following issues after setting up the router.
Firmware version 3.0.0.6_102_37025-g530f5da_954-gd3ae6
1. VPN Server IPSec Client connect may cause the router reboot itself, even sometimes can connect but cannot browser the internet.
2. If any clients joined the 6hz channel. It will not possible to turn off Smart Connect to manually adjust the Wifi channels settings. Click Smart Connect OFF button and then Apply but no response, cannot switch to the Channels setting page until all clients disconnect from the 6hz channel.
2. One of the CPU coil always stay at 100% usage. It may happen on any of 4 coils randomly. Reboot the router may fix but not absolutely work.
4. Adjust settings may hang the router, need manually power off and on.
Any members had these issues ? I had reported to Asus support but no positive reply, just telling me they had no such issues.
Thanks in advance.
Tuesday
Same issue here - anyone successfully fixed it?
