Router slowing down internet speed
petarbg
Hello, please help.
I have an RT-AC88U router. I've found that it is reducing my internet speed. The maximum I am getting on the speed test is 94 Mbs but my ISP is providing 400Mbs.
ISP modem is plugged into RT-AC88U and it worked fine for years until recently. As soon as I directly connect ISP router, everything is fine with the speade which leaves ASUS router as a problem.
I've tried different cables, all LAN ports and also factory reset, and various firmware updates but there is no change.
Please help.
7 REPLIES 7
It is an Ubee EVW32C . I did a reset
petarbg
The problem is a faulty WAN port on the ASUS router. The solution is to enable dual WAN and then use LAN port as WAN. Now it is fine but I will never buy an Asus device again.
Hi @petarbg ,
We sincerely apologize for the issue you encountered with the WAN port.
To prevent further inconvenience, we recommend sending your router to an official service center for inspection and repair.
You may refer to the service center location link below or contact local customer service team for assistance with the repair process.
Official Support | ASUS Global
