01-08-2025 11:05 PM
I am looking at the ASUS RT-BE92U. Can you recommend it? I already own an AC68U and AC57U V3. Can I connect all these to AiMesh?
01-08-2025 11:59 PM
Hi @Sampy ,
Thank you for your interest in ASUS router products!
Regarding the RT-BE92U, you can refer to its product specifications and feature introduction below.
ASUS RT-BE92U|WiFi 7|ASUS Global
The RT-BE92U, AC68U, and AC57U V3 all support AiMesh and can work together to form a stable Mesh network.
Typically, we recommend setting the higher-specification router as the AiMesh main router to achieve optimal performance.
For detailed steps on setting up a Mesh network, please refer to the FAQ below.
[AiMesh] How to setup AiMesh system (Web GUI)? | Official Support | ROG Global
We recommend selecting a router that meets your usage needs and budget. Should you need further assistance, feel free to contact us anytime.
Thank you!
01-09-2025 02:54 AM
I have set using TUF Gaming AX3000 as node and no problem.
