ET8 V1 Node Not Transmitting Wifi 6E SOLUTION
MKFlyers2K
Kudos to @SpaceAntelope   for guiding me in the right direction. I also did some testing with some changes and found the following. ASUS' firmware is poop. Any deviation will make 6GHZ not work!
1. Download firmware 3.0.0.4.388_23759 for your version, install that firmware on ALL the ROUTERS!
2. On node unit, turn off via switch.
3. On MAIN Unit, Factory reset via WPS method. Turn off unit. Push and HOLD WPS button, one light will come on then another. Once that light goes off let your finger off the WPS button. Youll notice the light stays off. Thats OK! Turn the unit back on.
4. On NODE Unit(s), Factory reset via WPS method. Turn off unit. Push and HOLD WPS button, one light will come on then another. Once that light goes off let your finger off the WPS button. Youll notice the light stays off. Thats OK! (Dont turn on unit just yet)
5. Setup main router. Whatever you do, do NOT use/enable SMART CONNECT. Do NOT use anything else other then WPA2 for your 2.4 and 5ghz signals. I dont know why, but these settings have to be as I described. You can mess with pretty much any other setting, but I dont know if that will kill your 6ghz signal at your node. Trail and erro come into play. Also the firmware is VERY finicky. So if 6ghz stops working you may have to repeat the steps above. Again, I dont know why, but that was my experience. ONCE YOU DO ALL OF THAT DISABLE AUTO FIRMWARE UPDATE!
6. Ready for some fun now? Because ASUS' firmware is literal CRAP, do whatever you have to do to get your node to link up to the main router. Once you do the node will be in the spot where you want it or you can place it where you want it. Keep in mind, if you are using a WIRELESS backhaul the 6ghz might not work because it MIGHT be used has your backhaul. Other then that ENJOY your 6ghz on the node now!
UPDATE: After tweaking with it (again) now im regretting it. 6ghz isnt popping up on the node. I factory reset everything (again) and I couldnt quite get the 6ghz to work on the node, but i rebooted the entire network via system settings  (within AIMesh) and it seems to work again. This is crazy. I just don't get it but whatever. Fix it ASUS!
I sent asus emails and gave them logs. Now its time to FIX IT!
1 ACCEPTED SOLUTION
Accepted Solutions
MKFlyers2K
see first post for solution...
6 REPLIES 6
Aureliannn_ASUS
Hi @MKFlyers2K ,
We sincerely apologize for the issue you are experiencing. We would like to confirm the following details:
  1. Does the issue only occur with the 3.0.0.4.388_23759 firmware version?
  2. What is your current network architecture? Do you have a main router and a node?
  3. If you swap the main router and the node, does the issue still occur?
  4. Are you using a wired or wireless backhaul? Does the issue occur in both scenarios?
  5. You mentioned that you have already submitted a problem report. Please send me the following information via private message so the team can locate your report:
  • Product serial number
  • Problem report submission time
  • Email used in the problem report
  • Time when the issue occurred
  • Device MAC address
  • Current network architecture diagram
We greatly appreciate your understanding and cooperation.
Hello I will respond to this as soon as I can. Currently at work.
Hello, please see my responses below...
  1. Does the issue only occur with the 3.0.0.4.388_23759 firmware version? No the issue is NOT occurring on this version , it occurs on ANY NEWER VERSION.
  2. What is your current network architecture? Do you have a main router and a node? Main Router Ethernet Backhaul to Node
  3. If you swap the main router and the node, does the issue still occur? So if firmware version is NEWER then above, if you factory reset and reconfigure 6e will only work on main. If you factory reset and move node as main, and main to node, you still only get 6e on main.
  4. Are you using a wired or wireless backhaul? Does the issue occur in both scenarios? Wired, and yes issue also occurs on wireless.
lelraptorl
Hi. Had the same problem, this solution worked. Unfortunately with the older firmware.
Anyway thanks a lot! @MKFlyers2K  @SpaceAntelope
