RT-BE7200 Random disconnections
shileno
Hi, I have an AIMesh setup with two RT-BE7200 for a few weeks already and clients suddenly lose the WiFi connection.
Symptoms are very similar to this thread https://zentalk.asus.com/t5/networking/rt-be92u-on-going-random-losses-of-internet-wan-access/td-p/4...
So I was looking at maybe applying the same solution, but I noticed something weird. The firmware on my router (auto updated via the UI) shows this firmware installed in both routers:
 RT-BE7200 : 3.0.0.6.102_37103-g8c8d7fb_980-gbd310_BB0B
But looking at the Support/Download page of the model, the latest firmware listed is a different one:
ASUS RT-BE7200 Firmware version 3.0.0.6.102_37094
Does it have the proper firmware? Should I manually install the one in the router support page? Is it safe?
Thank you all in advance.
6 REPLIES 6
jzchen
Zen Master II
Sometimes the firmware is uploaded to the server ASUSwrt accesses before the web page.  I wouldn't worry about it being incorrect.
In the thread you reference the OP has a USB device connected, which can make noise that affect WiFi.  If you are having trouble with WiFi and have a USB HDD/flash drive connected my first advice would be to disconnect it and see if the dropping stops.  I believe someone relocated the USB with a quality shielded cable and this helped for someone with the noise issue...
shileno
Hi, thanks for your response.
No, I don't have any USB device connected.
I referenced that post because I do see in the logs the same
kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
kernel: WLC_SCB_DEAUTHORIZE error (-30)
The firmware I was able to find it under the RT-BE88U, and seems to be the same router, which makes it more confusing.
Which firmware should be using?
Hi @shileno ,
We sincerely apologize for the delayed response due to the recent holiday, as we were out of the office.
Regarding your inquiry, the RT-BE88U/BE7200 WiFi 7 AiMesh Dual-Band Gaming Routers are the same model. We recommend that you download the latest firmware (3.0.0.6.102_37103) from the RT-BE88U official website and check if the issue persists.
We greatly appreciate your understanding and cooperation.
RT-BE88U|WiFi Routers|ASUS Global
Got it, will try it this weekend and let you now.
Thanks!
