Router slowing down internet speed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-06-2025 06:14 PM
Hello, please help.
I have an RT-AC88U router. I've found that it is reducing my internet speed. The maximum I am getting on the speed test is 94 Mbs but my ISP is providing 400Mbs.
ISP modem is plugged into RT-AC88U and it worked fine for years until recently. As soon as I directly connect ISP router, everything is fine with the speade which leaves ASUS router as a problem.
I've tried different cables, all LAN ports and also factory reset, and various firmware updates but there is no change.
Please help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-07-2025 02:00 AM
Try to clone the MAC address of the device you connect directly to the modem and get full speeds.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-07-2025 10:46 PM
Hi @petarbg ,
Thank you for reaching out to us!
Based on the issue you encountered, we suggest checking the following:
- Log in to the router management interface and verify whether the WAN port connection speed is 1Gbps. If it shows 100Mbps, it might be a speed limitation issue.
- Ensure you are using a network cable of Cat5e or higher standard, and try cross-testing with other cables.
- Navigate to the "Adaptive QoS" or "Bandwidth Management" section in the router interface, disable all QoS settings, and check if the issue is resolved.
- Confirm that the router firmware has been updated to the latest version.
If the issue persists, consider performing a factory reset on the router. Please refer to the related FAQ for detailed instructions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-08-2025 09:18 AM
hello, thank you.
1. Yes, it says 100Mbps . So who limited it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-08-2025 09:28 AM
Did you try rebooting the modem/ONT?
