Asus RT-BE92U random loss of internet connectivity
mattgod69
Hi
I have been having several problems with this router since 'upgrading' to it.
Some users report random loss of connectivity.   This was mainly affecting iphone users, but i have had issues with my LG TV and some other devices.
I am also getting strange AiMesh behaviour.  I have a couple pf old routers and a RP-AX56 extender.  The RT-AC68U seems to be stable all the time but the RP-AX56 behaves very strangely, even when not located very far away from the router.  The RT-AX82U also does not like the AiMesh although this is located a bit further away.
All devices are on the latest firmware.
A couple of minor points.... has anyone noticed that  the internet speed checker has gone (under Adaptive QS tab).  All i now have is a graphic (see screenshot)?
Also, are you only allowed to have one main network? If I try and add another, it comes up with the message (your rules have reached the maximum' (see screenshot). I cannot see where to change this rule though? Is it possible to change this?
Matt
Alex52
If everything worked before the update. You can try using ASUS repair tool to go back to the earlier software. Your GUI settings may have also been corrupted by the last update and could need a reset.
