Asus RT-AX59U AX4200
Mb3663
My router is not connecting to the internet /light is not turning blue. It stays in the green light only. NBN is working fine and old router works. What do I do next?
Aureliannn_ASUS
Hi @Mb3663
To help us confirm the network issue you're currently experiencing, we kindly ask you to confirm the following points:
  1. Has your router's firmware been updated to the latest version?
  2. We recommend attempting a Hard Reset on your router and then rechecking. Please refer to the FAQ link below for the relevant steps. [Wireless Router] When Standard Reset Isn’t Working: Hard Factory Reset - Models list | Official Sup...
  3. Are both wired and wireless connections unable to access the internet at the moment? We suggest cross-testing with different Ethernet cables, Wi-Fi bands (2.4GHz/5GHz), and Wi-Fi channels to see if the issue persists.
Thank you for your cooperation!
