Update failed
MONSTER
In Zenfone max pro M2 from past 5-6
update get failed. Software update is available pops up in notification bar. But every time it downloads and failed
After done all the things it shows up with popup and says your device is reverted to It's original configuration
56 REPLIES 56
MONSTER
veeharish2005
https://zentalk.asus.com/en/discussion/comment/116157#Comment_116157
I think you need to take your device to a service center
What will they do?
veeharish2005
Zen Master I
veeharish2005
Zen Master I
Anandu
https://zentalk.asus.com/en/discussion/comment/116165#Comment_116165
https://www.asus.com/support/FAQ/1042349
https://www.asus.com/in/Phone/Zenfone-Max-Pro-M2-ZB630KL/HelpDesk_BIOS/
Try this. Instructions above. Follow correctly. Also available in the website link above.
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB631KL/UL-ASUS_X01BD-WW-16.2017.1912.072.999-user.zip
Once this is done try checking update.
(this is actually a downgrade firmware target to 72version, but this may work.)
Note: doing this will probably wipe the data
RadeonPS
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/comment/116168#Comment_116168
It will which is why BACKUP is necessary.
MONSTER
veeharish2005
https://zentalk.asus.com/en/discussion/comment/116169#Comment_116169
Reflash the firmware
I used downgrade for pie and its complete now.
