BOOTLOOP/STUCK ON LOGO
Junrel
Hello guys I just want to know for some users here experienced stuck on logo or bootloop. My question is what is the reason why your Asus Max Pro M1/M2 got Bootloop or Stuck on logo?. What android version or build number your phone before it happened.?What did you do before it happened?
Thank you so much. I hope this bootloop issue will be fix. PLEASE ASUS! 😢
Christine_ASUS
Community Legend II
Hi Junrel
Thank you for your asking. Are you facing the issue? Please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable. If you can not access the phone, please check if your google account or microSD card have auto backup your data.
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key"
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Factory data reset"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/
Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
If the issue remains after the Factory Reset, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/
If it is impossible to access the service center during Covid-19 period, please try Call us: https://www.asus.com/support/CallUs
