Asus zenfone Max pro m1 SD card can't move the file
muthum570
Im facing sd card write access problem can't move any files to sd card couldn't move file error unknown
28 REPLIES 28
Christine_ASUS
Community Legend II
Hi muthum570
Thank you for your asking. Kindly provide the information below so that we can better assist you.
1. Can other SD card work properly in the same device?
2. Can the error SD card work in other devices?
3. Does the issue occur while moving the file from SD card to SD card; or from SD card to the internal storage of the device?
4. Please provide me the screenshot of Settings>Storage
muthum570
Card working in other devices properly
muthum570
Im formated sd card more than five times still i can't move any files to sd card im facing this problem 429 build
Christine_ASUS
Community Legend II
Hi muthum570
Thank you for your reply.
1. Can SD card work in Android 9?
2. Does the issue appear right after any system/apps' download or update?
