Unusual issue with vibration not working, but only for phone calls
Skwara
Asus Zenfone 10, Android 14, build WW_34.1004.0204.201
I keep my phone on vibrate nearly all the time. For a month or two, I started observing a situation, where the phone does not vibrate during incoming calls, but the vibration works all right for notifications or during sensor tests. It seems only phone calls are affected.
I often observed the issue in the mornings, after a night of charging and being in the "do not disturb mode". I tried disabling the "do not disturb mode" for a couple of days and the issue did not occur, which suggests it might be the reason, but I cannot be sure, as the problem does not occur always, but once every couple of days.
To fix it, I only need to enable the sound and go back to vibrate, but it's still an issue, because it results in always missing the first phone call to realize, that the vibration broke again.
I generated the "General" logs. I did the following:
  1. Tested, that the vibration on calls works by calling myself through Skype.
  2. Enabled "general" logging.
  3. Connected phone to charger, which enabled the "Do not disturb" mode via "Bedtime" mode.
  4. Left the phone overnight.
  5. In the morning, disconnected the phone from charger.
  6. Tested, that the vibration on calls doesn't work by calling myself through Skype.
Logs: https://drive.google.com/file/d/1quG3FP0v_KFJ2fJxsikIpAsUal8Yleij/view?usp=drive_link
Please let me know when you acknowledge the issue. Thank you 🙂
0 REPLIES 0
