Low Loud Speaker Sound Volume Max Pro M2
marcuslex13
My Asus Max Pro M2 has a very very very weak loud speaker sound volume. I have seen ridiculous solution like cleaning the speaker area. I have old models that are 3 times louder than this failed model.
I noticed that discussions on Max pro series sound issue is hard to find, and so I am starting this discussion to see if there are other fixes to the issue.
Should I be resigned to the fact that I made a mistake in choosing Asus as my Phone? Maybe Audio is where this company struggles.
marcuslex13
Phone model Asus Max Pro M2 Android 9
Media source is Youtube. I watched the same video using 2012 model phones such as Lenovo A7000 and Microsoft 535 and Asus is the worst.
Loud speaker Sound seems to be louder after every re-start then goes back to weak. Software issue - fix it Asus.
I have tried some sound booster app but they all make the quality low, some dialogue are barely audible. I have Volume Booster GOODEV and SUPREME VOLUME BOOSTER and yet the Volume od ASUS is very weak/
Its a software issue, don't try to skirt around it by demanding more information.
Falcon_ASUS
marcuslex13
@marcuslex13
Everyone has different acceptance of sound.
If you think there is a problem with speaker sound volume, I would suggest you bring back your mobile to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
marcuslex13
For those with Max Pro M2. if the sound level increases every time you restart then this is a software issue that ASUS will avoid to fix.
