07-13-2020 12:23 PM
07-15-2020 09:54 AM
07-16-2020 04:46 AM
07-16-2020 05:10 AM
AJ1This is 5000 mah battery should it still take less than 2 hours with the stock charger?generally all mobiles gets full charged within 2 Hrs, it may be an update issue or battery issue. if battery issue then you need to replace with a new battery, if update issue, u need to wait for an update or if there's way to downgrade / remove existing update.
07-16-2020 05:31 AM
Sardar JiNo, they advertised this phone to charge in 2 hours and 45 minutes at launch. But every company test's their devices in the best case scenario.https://zentalk.asus.com/en/discussion/comment/97091#Comment_97091
07-16-2020 06:02 AM
veeharish2005Alrightyhttps://zentalk.asus.com/en/discussion/comment/97093#Comment_97093
Charging speed will be affected by the temperature of the device , charging speed will change at various percentage of the battery. It will also be affected by the background processes (antivirus scanning in the background etc) so taking all of this into account your device will be charged in 3 hours to 3:15 hours.
