11-05-2024 11:17 PM
I have found the solution!
Many of us have charging problems. Some cables work, some cables do not. I experienced this problem up to a point I could only charge with one old cable I luckily found somewhere.
Since I'm in a dusty environment I suspected fitlh and dirtyness. Cleaning did help slightly but not really. For months I've been in a unhappy situation.
BUT NOW..
I compared many cables and shape and size do differ. First I thought the usb C connector is too loose of a fit. Pinching it a bit was not the solution. Shortening the connector is! I grinded 1 or 2 mm off and now the standard cable my Zenfone 10 came with works again. At hyper speed!
Be carefull for sharp edges or dust and filings in the connector. Sand it soft and smooth and welcome the happy times.
Hope this will work for many others.
11-06-2024 05:48 AM
Nice info!
a month ago
Is that an appropriate solution to something that should be right out of the box? Yet another reason for Asus to issue a full refund imo.
