Bugs in notification panel after latest. 87 September update
punit_kl05
Hello Asus,
I am using Asus max pro m1 6gb Indian Variant. I never rooted my device. I just updated my device to latest Version WW-16.2017.2009.087. But after updating i found a bug in notification panel. When i use dark theme the notification panel has edges in left side but no issue while using light theme. I have also did wipe partition cache. Kindly fix it asap. Its looking weird.
Looking forward for your positive response.
I also attached the snapshots below.
8 REPLIES 8
veeharish2005
Zen Master I
punit.kl05
Hello Asus,
punit.kl05
Kindly check in your device if it happening or not . In dark theme notification panel has edges in left side only but on screenshot it showing edges in both side left & right.
but with light theme its not. On. 84 firmware there wasn't like that.
This is bug.. Need to fix.
This is not a bug. This is how it was since the .050 build.
You can see the same thing happening in white theme so it is not only happening in dark mode.
punit_kl05
Kindly share your screenshot in dark mode. Let me see.. Actually the problem is in dark mode i edges cut are only on left side of notification panel in my device. In light theme no issue. I haven't face any such issue before. And the strange thing is when i take screenshot the edges is evenly cut in both side.
That's what i saying this is bug.
veeharish2005
Zen Master I
punit.kl05
Both the dark mode and light mode are doing the same thing
punit_kl05
Yes its clear that white notification panel doesn't have edges but dark notification has edges.
