HEATING AND BATTERY DRAIN PROBLEM IN ASUS ZEFONE MAX PRO M1 IN LATEST UPDATE
psaravanankarur
Model Name: Asus ZEFONE MAX PRO M1
Firmware Version:0.87
Rooted or not:not
Frequency of Occurrence:
After latest security patch update phone battery drain and my mobile was heating to much in 5minutes.
Battery percentage drain in seconds:
100%-95 in 5sec
95-80 in 5sec
After 50%phone battery drain very fastly but in previous stable update battery performance was good when I upgraded my mobile to android pie phone perfomance was almost worse if you failed to problem .surely I will exchange my mobile. Worst perfomance now..😡😡😡
4 REPLIES 4
nidhin3
Zen Master I
Try to clear cache partition. You can find the procedure on youtube.
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
You may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
psaravanankarur
Victor01_ASUS
This is my mobile now usage .Standby time is ok or need to improve pls tell some.
Nishat
My asus still does not support vodafone idea volte function
