Huge problem with notifications
Aki_Mo
Model Name: Asus zenfone 9
Firmware Version: WW_32.2050.2050.34
Rooted or not: NOT ROOTED
Frequency of Occurrence: all time with locked phone (details below)
Hi
Andoid 12 (latest via OTA)
non-rooted
The problem is that while there is no problem with SMS / WhatsAPP notifications, no other ones come
Other notifications come only in 2 cases
- unlocks the screen (backlight is not enough, I have to unlock it)
- the phone is charging (then they come normally)
First, I set everything according to my own logic and intuition (it has worked well for the last dozen or so years of using electronics)
The problem still existed - so I looked online and set everything up as people suggested - THE PROBLEM STILL EXISTS
Later I found the website dontkillmyapps
I set up the entire system and applications according to the information provided
I even installed an application related to this website that checks the killing of applications, after a two-hour test, all results came out 100% (i.e. nothing killed according to the legend of the tests)
I turned off optimization, turned on dynamic mode, turned on flexi, turned off battery adaptive mode - in short, everything possible at the expense of battery life - ZERO result
Phone unlocked - notifications come, phone locks - they come for about 1-2 minutes and end
Previously, I used A11 (I did not upgrade to A12) on LG g8s and there were no such problems
Mansi_ASUS
Hey @Aki_Mo,
This seems strange. Can you please share the log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file via PM.
ambrat
I am facing similar issues. The notifications on some apps are only received when I unlock the phone or put it on charge.
Is there a solution to this problem? Seems very weird to me. At times frustrating.
