System UI stopped working
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-29-2022 03:34 PM
I still have a problem with the "system UI stopped working"
With UI elements not in the place that they should be, for example the top notification bar in landscape is one half of the screen with the rounded corners on the middle of the screen while they should stay at the corner
I am desperate cause it really ruins the user experience.
What will fix it?
are there any solutions?
will factory reset help?
What will fix it?
67 REPLIES 67
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-31-2022 01:55 PM
Just turn it off and everything will be as in 11.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-31-2022 10:47 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2022 01:51 AM
Hi @koallawindows10
Thanks for reporting this issue.
1.Could you let me know which firmware version are you right now?
2.Does it happen while using some specific app?
3.Could you share a screen record or video of this issue?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2022 11:17 AM
tupatatapaYou may not have it, but after disconnecting, these problems disappeared.https://zentalk.asus.com/en/discussion/comment/203124#Comment_203124
Turning off this doesn't change anything.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2022 01:01 PM
For me it helped to turn off the night light. I only get crashes of System UI if night light is on.
