Google Assistant Does not work correctly
D_IMAN
Rising Star II
Hi all.
Google Assistant responds to "Ok Google" every other time...
1 - 3 days responds to the command stably, then no reaction to the phrase "Okey Google". What with the screen off, what with the on ...
Should you turn off / on the device, and how long does this function work again!
What in the OS can jam the operation of this application through some?
The version of android and this application is up-to-date.
Device model - Asus Zenfone 8.
33 REPLIES 33
Not applicable
This creates huge problems in a car. While driving.
Mihoo
There were no problems with "ok google" before updating the firmware. (despite the same case on our zenfones). Checking and removing the cover is not the solution here.
D_IMAN
Rising Star II
They are in no hurry to fix the problem!
D_IMAN
Rising Star II
Today I re-recorded the voice, rebooted the smartphone.
The response to the command worked for several hours ...
Now there is no response to the team ...
Firmware 31.1010.0411.89
What happened?
On the previous firmware it could work up to 5 days ...
Mattias_ASUS
Hello, I'm sorry for the late reply.
Our team has been informed of the issue and will be waiting for a solution.
