Display auto brightess doesn't work
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-23-2021 03:24 AM
Just when I've bought my phone I've set brightness to auto.
Now when I'm going to Display settings and I'll choose some brightness level for example "20%" and go outside when sun is bright, display won't make itself any brighter. Same when setting to "80%" ang going to dark room. It's still 80%.
Please fix this, it's very annoying right now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2021 04:14 AM
lukasz.szabelskiDo you have auto brightness turned on?Today I've noticed that something's wrong with auto brightness. After yesterdays update my screen brightness was set on 95% and battery got low very fast. Same after charging from 100% to 85% in 4 hours without using anything, no apps, no calls, no gps etc.
Can you record your ZF8 with one of your other phones to show the problem where it doesnt change brightness if you set it to low (10%?) and then shining the flashlight on it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2021 04:30 AM
Sure, I'll make some video 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2021 04:48 AM
I've set both Asus Zenfone 8 and Lg G7 display brightness to 18% and as you can see "Auto" is enabled on both. When I've shine the flashlight on it, Zenfone display go to ~25% from 18% while LG goes from 18% to ~100%. Without flashlight Zenfone brightness go down a little while LG is back to 18%.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2021 04:50 AM
(thanks , downloaded)
