06-13-2021 02:21 AM
07-16-2021 12:11 AM
woody.wwHi Woody, i did that specific test and i can confirm that forcing network to 2G/3G makes a big difference over 2G/3G/4G. I never tried 5G because my network provider does not support it yet. Of course it was just for the sake of testing, it's clear that a device without 4G access is useless.https://zentalk.asus.com/en/discussion/comment/176412#Comment_176412
Seems like things have been improved over the last month. Back then even airplane mode drained mobile network standby. Now, as you can see below, there's no drain there. 3% over 9 hours -> 0.33%/hour. The 3% comes almost only from "phone standby", which sounds reasonable (although doesn't match the 0% from my previous phones).
Looks like in my case there's no issue at all (especcialy compared to what @Salvatore is getting 😕 ).
Next things I will test is just disable wifi/mobile data over night. No flight mode as I want to be available for messages/calls. Another test I can do after that is changing the preferred network type from 2G/3G/4G/5G to 2G/3G/4G or even 2G/3G.
07-16-2021 01:42 AM
Alex'sI was using advanced with everything moved to the left, but I also saw the CPU freq never goes belo1.3, same behavior with dynamic,so leaving it in dynamic for now.Hi guys, which system mode in battery do you use?
I mentioned that in mode advanced the cpu never goes below 1,3ghz, even the cpu is set to minimum.
I mode dynamic the cpu goes down to 0.3ghz which should be correct.
Kind regards
07-16-2021 04:17 AM
Admin【Version】
30.11.51.83
【Model Name】
ZenFone 8 (ZS590KS)
【Release Date】
2021/07/14
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Optimized system stability
- Improved Pocket mode threshold and detection
- Optimized phone call quality
- Improved camera quality
- Added AOD ‘Tap to show’ function
- Improved thermals for ASUS Camera
- Improved the thermals for phone calls during suspend
- Enabled VoLTE & VoWiFi on Vodafone & Deutsche Telekom (Netherlands)
- Enabled VoLTE & VoWiFi on Deutsche Telekom (Hungary)
- Enabled VoLTE on Vodafone (Ireland)
- Enabled VoWiFi on MTS (Russia)
- Updated Android security patch to 2021-05-05
[210712]ZenFone 8_EU_30.11.51.83
07-16-2021 05:05 AM
07-16-2021 08:33 AM
