Battery drain
DramaLama
I went from the best battery, to a bad one in two months. I did factory reset and it was the best battery again. Now in back to a bad battery again.
 this is when it was good
 and this is bad,
All apps use 10+% per hour now too
 i dont get it :(.
I also use three different apps to monitor battery. And i always kept an good eye on the battery performance since i was so happy with it. It feels like a software thing. But all the apps and built in battery monitor show normal signs. Im puzzled.
Mansi_ASUS
Hey @DramaLama,
When did you first notice the issue?
Also, can you please mention which system mode are you currently using?
