Phone audio from wrong speaker
guntherguerra
Whenever I recieve a phone call the callers audio comes out from the bottom speaker. I need to toggle speaker ON/OFF for it to come out the correct speaker.
I just upgraded to Android 10. 8/256gb US model
I have done basic troubleshooting. Power cycle, safe mode, clear cache on phone app. Etc
Any other suggestions?
69 REPLIES 69
guntherguerra
Indeed I am on Tmo
I also have a mexican sim on 2nd tray. Calls there have same issue ( but its piggybacking off tmo anyway)
Whatsapp calls dont cause the issue though
_jis_
Zen Master III
guntherguerra
I just got the FOTA update automatically. I think just the differential update Rebooted phone, I will try to clear cache and all that to see if that solves it.
https://zentalk.asus.com/en/discussion/comment/39441#Comment_39441
https://zentalk.asus.com/en/discussion/comment/34406/#Comment_34406
justinleon2113
Hello. Just thought I'd add I am also experiencing the same issue even after the .119 update with mine. I actually did a complete erase and then reinstalled Android and the problem persists. I am using Ultra Mobile (an MVNO of T-Mobile) in USA.
murleenair
Issue is the same. I have my phone updated to QP1A.190711.005.WW_Phone-17.1810.2001.119 and the Android Security Patch Level 5th January 2020.
Since the last FOTA update, my Asus Zenfone 6 is behaving like this. When you answer the call, it first starts the Loudspeaker and I need to toggle the Speaker button to bring it back on earpiece. I have checked this from multiple incoming calls. I am on Vodafone network(India).
Is there any solution to this problem yet. Or if it is going to get fixed in the next update then I have to do this annoying toggle till then.
Need Help!!!!!
Regards,
MurLee Nair
niceded
murleenair
Need Help!!!!!
Regards,
MurLee Nair
I have the same issue after I updated to Android 10. Also T-Mobile user.
Asus, please help.
