Android 10 update restart problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-30-2019 01:06 PM
Just received an update for Zenfone 6 ZS630KL through FOTA and unfortunately I have updated it. After update phone restarted a few minutes without success to open.
After a lot trial, recovery screen opened and I made a factory reset and lost all data. Anyhow after factory reset phone opened and set up all applications. But IF I switch off the phone, again and again I face off restart problem. IF I see recovery screen , phone can start after factory reset again.
Anyone can help and say what should I do. there is no Asus CENTER which supports this model in my country.
Software version : WW_17.1810.1910.73
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-23-2019 01:23 PM
okurorhanOur software team would like to log your phone. I'll send you a PM with instructions.https://zentalk.asus.com/en/discussion/comment/32831#Comment_32831
Yes I do but if i switch of the phone when it is set up in Turkish I know very well that I had to factory reset it till new version software comes subject to problem in softwares is sorted out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-15-2020 06:53 AM
I am having the same problem. I just got my Zenfone6 today, transfered my all data and set my phone. After the new updated I turned it off and I had a message that Android loading is failed. So I had to reset it to factory settings. It happened twice and my language was set as Turkish. Now I changed it to french setting it. Please help me with it. If you can givea solution I will be very happy. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-15-2020 12:29 PM
edaunsal82I'll send you a PM.Hello All
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2020 09:30 AM
edaunsal82Hi!Hello All
I had the same problem almost 1 month ago and I gave it to the service couple of times to have it fixed. It was a tiring experience... However, the problem still arises and the last time I received the phone from the service, there were scratches and they decided to change it with the new one. The new one doesn't offer the new update yet, but I am sure after reading all of the above that I will have the same problem if I use it in Turkish with Android 10 update. Waiting for your good news.
Best.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2020 08:46 AM
Unfortunately it is not working and causing restart problem if device is set up in Turkish. Software team can easily set up a ZenFone 6 language as Turkish and switch off the phone. Than they will see that they will not be able to restart the phone till they factory reset. Unfortunately during last 2-3 months they couldn't fix it and many people knocked the door of service. Not only Turkish also many other languages lives similar problem as i heard from different websites. Thanks for helps to sort this problem
