ZenBook Pro Duo i9 12th gen UX582 connect 3 external 4k monitors for office work
darkwitch
System: Win11Pro
Battery or AC: AC
Model: UX582ZM-H2015X
Frequency of occurrence: n/a
Reset OS: n/a
Screenshot or video: n/a
Detailed description:
Hi, I'm considering purchasing the UX582ZM-H2015X (i9-12700H, RTX 3060) for office and travel work. In the office I have 3x 4k 27" monitors (DELL U2720Q), they support:
USB-C / DP 1.4
HDMI 2,0 (HDCP 1,4/HDCP 2,2)
In the office I'll be using just the external screens. I Understand to provide adequate cooling the laptop should be kept open. Some questions though:
Can I connect the ux582 to 3 external monitors using both USB-C and HDMI of the laptop?
Will I get 4k / 60Hz on all screens? If not which ones?
Will the screen pad still work or does it have to disabled?
Will all external screens have the same 'dim' level (I've read some reports that some ports provide dimmer look)
Are there any other limitations I should know about?
4 REPLIES 4
Falcon_ASUS
darkwitch
  1. System: Win11Pro
  2. Battery or AC: AC
  3. Model: UX582ZM-H2015X
  4. Frequency of occurrence: n/a
  5. Reset OS: n/a
  6. Screenshot or video: n/a
USB-C / DP 1.4
  1. Can I connect the ux582 to 3 external monitors using both USB-C and HDMI of the laptop?
  2. Will I get 4k / 60Hz on all screens? If not which ones?
  3. Will the screen pad still work or does it have to disabled?
  4. Will all external screens have the same 'dim' level (I've read some reports that some ports provide dimmer look)
  5. Are there any other limitations I should know about?
@darkwitch
I will forward the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Falcon_ASUS
darkwitch
  1. System: Win11Pro
  5. Reset OS: n/a
USB-C / DP 1.4
@darkwitch
1.Can I connect the ux582 to 3 external monitors using both USB-C and HDMI of the laptop?
>>Yes.
2.Will I get 4k / 60Hz on all screens? If not which ones?
>>Yes.
3.Will the screen pad still work or does it have to disabled?
>>It can be used normally without disabled.
4.Will all external screens have the same 'dim' level (I've read some reports that some ports provide dimmer look)
>>This is determined by the external LCD itself.
darkwitch
Thank's for the help, I had the laptop for a few days and can confirm all 3 external monitors were working 4k @ 60Hz with both laptop screens working - a whooping 5 screen workplace 🙂 However the laptop was a bit too large for my taste, so now I'm considering the pro 14 duo - so I've posted a similar question here:
https://zentalk.asus.com/en/discussion/64197/zenbook-pro-14-duo-i9-12th-gen-ux582-connect-3-external...
ASUS_Bot
Rising Star II
