2 weeks ago
I bought this refurbished Zenbook Duo 14 with specifically Windows 10 on it, and I had an issue with it as it arrived, because the Windows was already set, but it was not possible to reset it. It had no background for a simple factory reset.
After a long conversation with the seller, who gave me 12 months warranty services btw, we decided that I will do a fresh Windows install (for some refund of the price) - which I did after recovering from an illness (likely Covid) and until that happened, I basically did nothing with the laptop, it just sat on the side.
So I have no idea, if before installing Windows, the camera worked or not. I just hope it did.
Somehow I hope that this is just a fresh installation issue, which can be solved somehow, without having to send back the laptop for repare.
At this moment, the laptop seems to work flawlessly, only there is no Camera device found on it, so Camera does not work at all, nor does Windows Hello.
In the Device Manager, there is no Camera.
I can tell when I look at the top of the screen, it really seems to have the camera in there. Now I know this should be an IR camera, but I could not find any specific driver for it on Asus website.
Unfortunately, the laptop was already registered - so I can't ask any help for it through Asus. I did call them, but they said the registration has to be cancelled from the previous owner's side - now how to do that?? I can prove my purchase - but noone is interested in that.
So I have updated BIOS and there is latest Windows 10 updated on it as well.
Meanwhile the seller was on holiday but he is willing to do anything to make it work, now that he is back - I just thought I ask here too for some help, before I have to send it back for repare. I read other posts here, where Camera issues were sounding similar to mine, although in a different model, not in Duo.
So if you have any idea, please do let me know.
Many thanks in advance
2 weeks ago
@swadarshan
It is recommended that you refer to the following FAQ to troubleshoot the problem.
[Windows 11/10] Troubleshooting - Camera problem
If you have followed the FAQ and reinstalled the driver, and the device manager indeed does not detect the camera device, we would recommend you to send your laptop for repair to further investigate the issue.
2 weeks ago
Thank you for the reply.
However, it does seem a bit to me, as if my post was not really read at all. I understand if it's a bit long, as I tried to explain all that already has been done - and the situation too.
No, there is no camera device found to be connected. So the "troubleshooting steps" would be perhaps a joke, only if there wasn't so many hours/days/weeks of hard work put into find any help with this.
There is no Camera Driver to be found on Asus Website for this model. In fact it is really hard to figure out what camera is actually in there? Somehow, they did not want to share that info with us. Or I am just too dumb to find it...
The best I could find was "HD camera with IR function to support Windows Hello"
(https://www.asus.com/laptops/for-home/zenbook/zenbook-duo-14-ux482/techspec/)
And I did not buy this laptop directly from Asus and it is out of warranty service by Asus. However, I do have a 12 months warranty service with the actual seller I bought it from, and yes, my only reason to write here, was to avoid having to send the computer for repair.
As above mentioned, I have seen similar issue here, but with different model. There it was suggested to "go into safe mode", and also to "update ASUS System Control Interface driver xxxx" (which driver I would not guess by myself to solve any camera issue...) - but that post is over 3 years old, and the "Community Legend II" member, who was giving seemingly good advice there, has also not been online since last year.
But hey. I appreciate that I got any reply at the very least.
2 weeks ago
@swadarshan
In the download section for your product model, there are camera drivers available (https://www.asus.com/supportonly/ux482ear/helpdesk_download/), indicating that your laptop should have a built-in camera ( the actual specifications may vary depending on the specific shipment). Based on the information you provided, if the device manager cannot detect the camera (i.e., no camera device), there is a higher probability of a hardware malfunction (assuming your laptop was indeed equipped with a camera when shipped).
2 weeks ago
There actually aren't camera drivers available for this model when switched to Windows 10, and the the driver there for camera also states: "Minimum OS Version : Windows 11 64-bit 22H2"
So I might be just too careful, but I did not want to risk it without anyone more expert advising me to.
However, it has been way too long time (since the laptop was bought and not being able to use it from day 1) and also way too much time and energy put into trying to solve it, so I had to except the inevitable, that it needs to be sent back for repair. So this has already been organized and it is being sent back this week.
Thanks for your replies.
PS: I truly believe it is an actual malfunction due to the complete fresh Windows 10 Pro install on it (perhaps together with the fact that upon arrival the laptop was MISSING the recovery background which is definitely not normal to begin with), but I guess will just have to see now the result of the repair. (The repair of some, who did offer 12 months warranty service on an item that was sold as "refurbished" - while it was sold not fully reset and was left with no recovery background on it to reset it - and then when I complained about such simple thing they just wanted to send me to a local IT shop to re-install the Windows 10 and offered price refund for that. So yeah I was really hoping to be able to avoid having to send it back.)
