Zenbook Battery
Malcolm29
The battery on my Zenbook charges & holds a charge but as soon as I unplug the power cord it switches off.  Nothing happens when I try to start back up on battery untl I plig the power cord back in.
My Asus states the battery is abnormal but states there are no problems after diagnosis.
Any ideas please?
Falcon_ASUS
@Malcolm29
May I know the full model name of the laptop you are using?
How to find Model Name
Based on your description, it is recommended to send it for repair to check if the issue is caused by a motherboard malfunction.
My model number is ZenBook UX325SA_UM325SA , i have already sent it to the service center but as per their observation battery issue (surprisingly in just the period of 9 months ) they have told me that they have replaced the battery. but now after 4 months, the same problem occurred. this is totally not acceptable for the such a premium laptop.
Same problem is there in my zenbook as well ASUS is making some cheap quality laptop with inferior materials.  I have purchased the laptop in month on July 2022 , in May 2023 i got an issue of battery where service center have replace the battery since it was under warranty and now again in oct 2023 same problem arises , now they are saying that you have to pay for the battery . i will never recommend asus to anyone in my office
