03-11-2025 08:36 AM
Plug in the power orange light flashing and white light flashing also the keyboard lights flashing same time as the white light.
Solved! Go to Solution.
03-11-2025 06:02 PM
@Johntarbuck
Based on your situation, we recommend referring to the following FAQ for troubleshooting.
Troubleshooting - Device Boot Failure or No Display After Boot (Black Screen)
03-19-2025 09:53 AM
Took the battery out and it worked just using the power adapter I take it that I should buy a new battery.
Thanks for all your help everyone.
03-11-2025 06:02 PM
@Johntarbuck
03-19-2025 09:53 AM
