Zenbook 14 UX434FL Screenpad 2.0 not working after newest windows 11 beta
Vamp
Zen Master I
System: i7+MX250+16G
Battery or AC: Both
Model: UX434FL
Frequency of occurrence: Always, Since last windows beta update
Reset OS: Yes
The screenpad does not show anything (only grey or black screen) when turned on. Taking SS tells us that the screenpad is working but not displaying anything to us in extended and second screen mode. In duplicate mode, the ss shows the main screen.
From my side tried resetting the laptop without cleaning the storage. Also tried to update the graphic drivers and updated intel I2C driver. Screenpad Optimizer didn't helped either.
12 REPLIES 12
Falcon_ASUS
Vamp
  1. System: i7+MX250+16G
  2. Battery or AC: Both
  3. Model: UX434FL
  4. Frequency of occurrence: Always, Since last windows beta update
  5. Reset OS: Yes
@Vamp
Please refer to the following FAQ for troubleshooting.
[Notebook] Troubleshooting - How to fix the ScreenPad 2.0 problems when it is not working properly o...Sorry for any inconvenience it may be caused.
Vamp
Zen Master I
Falcon_ASUS
https://zentalk.asus.com/en/discussion/59742/zenbook-14-ux434fl-screenpad-2-0-not-working-after-newe...
@Vamp
https://www.asus.com/support/FAQ/1041344/
Hi, This is the FAQ I used for restoring my screenpad as mentioned above.
Is anyone else is having this same problem?
Vamp
Zen Master I
Now I've seen it on another device also. Any workaround around this?
Falcon_ASUS
Vamp
@Vamp
Is the model of the other device also the same as UX434FL?
Please provide the following for my further confirmation.
1. The system version you are currently using (detail system information).
Which version of Windows operating system am I running?2. The BIOS version you are currently using.
[Notebook] How to check the model name and BIOS version | Official Support | ASUS Global3. Video of how the problem occurred.
