2nd Screen on Zenbook duo not detected
roymcpeake
After a windows update my small screen does work, I rolled back the windows update and it started working again, however after another windows update the screen is not being detected at all now.
I have updated all drivers for laptop and graphics card.
Falcon_ASUS
@roymcpeake
Could you please provide the complete model number of the laptop you are using?
[Windows 11/10] How to check the model name and BIOS version
Could you also let us know the system version and OS build version when it is functioning normally, as well as the system version and OS build version when it is not functioning properly?
We apologize for any inconvenience caused.
