Wireless card interfering with my audio
mr_dean
System: Zenbook
Battery or AC:
Model: ux390UA
Frequency of occurrence: All the time / network traffic
Reset OS: Win10
Screenshot or video:
Detailed description:Wireless card interefers with Audio Jack output
7 REPLIES 7
mr_dean
I've been eliminating most probabilities.
1- Bluetooth has no issues
2- No static if wireless card disabled
3- No static if usb wireless card is used through usb port
4- Earphones and speakers both have that annoying scratchy sound as soon as there's network traffic with 3.5 jack
Anybody has that issue and have you fixed it / replaced parts?
Blake_ASUS
Community Legend II
Hello mr_dean,
Please kindly check if your BIOS, Windows, Audio driver and Wireless driver are up to date, and let me know the version.
Also, may you record a video of this issue?
And what do you mean by "there's network traffic with 3.5 jack"?
mr_dean
All up to date with latest firmware / drivers.
Sounds like those old wired phones with static.
Download/upload of anything will cause this to happen. So anything plugged in the headphone jack while internal wireless network card working will cause it. Disabling sound card will not work.
Sound is perfect otherwise. ( Blutooth, internal speakers )
Blake_ASUS
Community Legend II
Hello mr_dean,
I see,
so under the same circumstance, when there is larger flow of internet, downloading or uploading,
only headphone would have issue, right? even using wifi and blue booth at the same time is fine?
May you try to connect to Ethernet LAN? or try another headphone?
I will try to test it and report this issue.
If you may provide a noise record, would be really helpful.
