05-08-2020 02:16 AM - last edited on 01-16-2024 12:48 AM by ZenBot
05-08-2020 07:21 AM
08-30-2020 10:03 AM
VampI did all the things you mentioned but nothing workedSame here... Maybe you should try turning the stream HDR off as well as playback settings to "optimize for battery life" also turning Tru2life helps... Also check Chrome or any other program in task manager for the battery consumption as sometimes chrome or other programs uses so much CPU usage due to some bug even when not using.
Also disable the not required application at the start-up in Task manager.
08-30-2020 11:58 AM
garvitag843use windows builtin power troubleshooter ,I recently purchased my zenbook 14 UX434FL and it was giving me around 9-10 hours of battery life, and suddenly after 4 weeks, it's battery life dip to 3-4 hours, Please help
Asus UX434FL Battery Problem
09-09-2020 01:18 AM
garvitag843You can check the battery degradation in intel graphics command center > system > power... After a year of use I'm at 43.4 Wh... Which is like 13% degradation...https://zentalk.asus.com/en/discussion/comment/78429#Comment_78429
