Hi everybody,
I have an Asus Zenbook 3. I'm writing here just to try to find a solution to my problem.
I need to find an USB C HUB desk which supports the recharge of my notebook through it.
I need it because when i'm working on my desk at home i need to connect a second screen (with HDMI), have some USB ports for USB keys, SD cards, and if possible also an Ethernet cable to use internet as fast as possible. But the point is: while i'm working, i can not disconnect the hub to connect the battery charger loosing all the other devices connections.
I started to use the Asus original 3 ports little desk hub (supplied together the zenbook3) but after time the hub usb c port stopped to work. i think it has been damaged using it for the charge through.
I bought another hub, different brand, but after a few days, i had the same problem.
any suggestions?
THANKS IN ADVANCE
