Screenxpert VIEWMAX issue
Samvel
System: Windows 11
Battery or AC:
Model: UX582HM
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hello,
Can't find ViewMax option in App Switcher when I drag a window on the desktop. According to all tutorials should be a ViewMAx option to spread app on both screens. But unfortunately I can find it. Maybe it should be activated somehow from settings?
Could you please explain ?
thanks in advance
32 REPLIES 32
ZBPD582
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/217841#Comment_217841
@j_e_a_farrington
I have reported the information you provided to the technical department for confirmation.
Thanks for the information.
I am having the same problem as those above. I shall follow this thread closely because I use viewmax a lot. I just updated to screenxpert 3 from screenxpert 2 today. I was willing to uninstall it and reinstall the previous version, but no such option exists. If a solution for this cannot be made with screenxpert 3, I hope a download link for screenxpert 2 can be given so those of us who need to use viewmax can have the chance to do so. Thank you
ZBPD582
I'm having the same problem as you! I hope this can be fixed soon.
Falcon_ASUS
ZBPD582
https://zentalk.asus.com/en/discussion/comment/217926#Comment_217926
@ZBPD582
Can you please let me know the model of laptop you are using?
Falcon_ASUS
j_e_a_farrington
https://us.v-cdn.net/6031231/uploads/QB3CNG85P4K3/2022-07-07-16-32-13.mp4
my screen record
@j_e_a_farrington
Confirmed by the technical department, please move the window by dragging, the option will reappear for you to choose. Thank you.
ZBPD582
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/218066#Comment_218066
@ZBPD582
Hi, I'm using a UX582HS
