Screenxpert VIEWMAX issue
Samvel
System: Windows 11
Battery or AC:
Model: UX582HM
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hello,
Can't find ViewMax option in App Switcher when I drag a window on the desktop. According to all tutorials should be a ViewMAx option to spread app on both screens. But unfortunately I can find it. Maybe it should be activated somehow from settings?
Could you please explain ?
thanks in advance
32 REPLIES 32
j_e_a_farringto
Hi these are the only options i have, and I had set them how you have in your image. I have noticed that the "Enable three finger tap" option is also missing from the menu too. I don't know if any of the others on this discussion also have this option missing?
j_e_a_farringto
Also the viewmax option is still missing!
Falcon_ASUS
j_e_a_farrington
@j_e_a_farrington
This is the reason for the different versions, so you don't see the option of "enable three finger tap".
Since we tested the viewmax option does exist, could you please help provide a video of the operation for us to confirm?
j_e_a_farringto
my screen record
Falcon_ASUS
j_e_a_farrington
https://us.v-cdn.net/6031231/uploads/QB3CNG85P4K3/2022-07-07-16-32-13.mp4
my screen record
@j_e_a_farrington
I have reported the information you provided to the technical department for confirmation.
Thanks for the information.
