12-05-202007:51 AM - last edited on 01-16-202404:20 PM by ZenBot
System: Windows 10 Home Battery or AC: Both Model: UX480FD Frequency of occurrence: Constant Reset OS: No Screenshot or video: No ======================== Detailed description:Screenpad does not work properly. I cannot launch apps or control screenpad settings etc.
Hi Blake, The OS is Factory version. I have not reinstalled it. I have tried to remove and reinstall screenexpert and graphics card. I downloaded all the driver updates from the support page and installed them. MyAsus shows now updates waiting. F6 works, screenpad lights up but does not respond to inputs, cannot open or run any screenexpert apps or control screenpad settings.
Yes, no apps work. Also none of the icons for settings etc work. In that mode it behaves like a faulty touchpad, when you tap on it it makes the main display do strange things. I have already found and followed that guide. It doesn't help. Although I was unable to reinstall the screenexpert drivers as there are none available for download on the download page for my laptop.
To follow up. I have gone through the guide to no avail. These are the Drivers/Apps that I could not download as they are not available on my product page. Do you have an alternate source? Serial IO I2c ScreenExpert Interface Driver Screenpad 2 Optimizer
Hello lgcarter523, Please refer to below link ZenBook 15 UX534|For Home|Laptops |ASUS GlobalYou may chose either of it to find the drivers for screenpad 2.0. I do hope that it will work for you this time, or we might need to go back to the beginning, to reinstall the 1.0 first, then let it run the upgrade 2.0 itself and all would be installed. Thank you.
