06-28-2022 04:14 PM
06-28-2022 08:07 PM
Becool@BecoolDetailed description:When I've bought ASUS Zenbook Pro Duo UX582H it came with windows 11. I've updated windows 11 and my speakers started working falsely. The sound is mostly scratchy, sometimes even non-existent. I tried everything but none of them worked. Help please?
Scratchy sound problem after updating windows 11.
06-29-2022 08:06 AM
06-29-2022 07:15 PM
sound@soundI have a similar problem with my Zenbook. I can't use it on Teams calls - the sound is very scratchy and inaudible to the audience. It is not my wifi as another laptop connects fine and has no issues. Any ideas how to fix?
07-02-2022 04:41 PM
Falcon_ASUSSorry for late responding.https://zentalk.asus.com/en/discussion/61659/scratchy-sound-problem-after-updating-windows-11
Could you please tell me the full model name you are using?
https://www.asus.com/support/FAQ/1030673/
Also please let me know, is there a condition of poor sound in all conditions?
Since you mentioned that the problem occurred after the system update, could you provide a list of system updates for me to confirm? Or please provide me the audio driver version you are currently using.
Does the situation improve if you remove and reinstall the audio driver?
https://www.asus.com/support/FAQ/1015070/
