never ending problem series of my Zenbook
munlu
One of my greatest regrets is buying this laptop (Asus Zwnbook OLED 3402.ZA). I have previously posted some problems with it. If you check my previous posts you can see how unhappy I am with the screen and heating issues etc. And as I use, I keep experienceing new problems. Here are some I discovered lately:
Sometimes the screen goes off itself and does not come back whatever you do. Only a reset solves it.
Sometimes this pc cannot wake up from sleep state. Only a reset solves it.
New problem added : Power button stucks at first start after opening the laptop.
I have a freshly installed and updated windows 11 with all latest drivers downloaded from the asus' website and installed. The only thing I am doing is browsing with google chrome with a few tabs open. I have only bitdefender av running in background.
11 REPLIES 11
Download this app, it has that option and many more.
https://www.thewindowsclub.com/fixwin-windows-pc-repair-software
Falcon_ASUS
@munlu
Have you also updated your BIOS to the latest version?
If you have confirmed that the BIOS version, system version, and graphics card drivers are all up to date, but the screen still cannot display properly, I would suggest you bring back your laptop to our service center for further confirmation.
Yes my bios is the latest version (310). I live in a different country so I don't think asus service center will help me. Btw if they do they will disassembly my notebook and ruin it probably. I paid a lot for this thing and I didn't deserve these problems at all. This device is such a waste of money and time.
btw, we have a new problem which is the power button stucks at first start after opening the first time. Never dropped this machine or never forced the power key.
@munlu
If you are experiencing a stuck power button issue, from our standpoint, we would still recommend sending it in for repair.
munlu
new problem:  touchpad click sometimes doesn't work. you have to tap harder a few times.
this machine is a total disappointment.
