Audio renderer problem
bijaylal_7
Hi everyone,
It has been a week, my asus Zenbook 14 doesn't play sound and I tried everything:
disabling and enabling driver, uninstalling and installing driver, many restarts. THe sound appears for a minute or so and Audio Renderer problem again. I bought the laptop 7 months ago only.
I would really appreciate any help. Thank you
Falcon_ASUS
@bijaylal_7
To rule out the possibility of a system fault, we recommend backing up your data and restoring the system to see if the issue is resolved.
[Windows 11/10] How to Reset (Reinstall) the Operating System
If the issue persists, we suggest taking the laptop to a service center for further inspection.
